| Engine stuck wide open | |
| Tweet Topic Started: Oct 19 2013, 01:53 PM (552 Views) | |
| alanwill | Oct 19 2013, 01:53 PM Post #1 |
I have changed the throttle position sensor and the engine is still stuck wide open. |
| chevystrong90 | Oct 19 2013, 01:59 PM Post #2 |
Certified Technician
Sounds to me like you replaced it with a TPS that was already stuck open(bad). I did that on a chevy truck and it come to be I bought a brand new(autozone) TPS that was already damaged, |
| Memphis metro | Oct 19 2013, 02:01 PM Post #3 |
Check throttle cable adjustment and throttle plate closure clearance. |
| vr4 | Oct 19 2013, 02:24 PM Post #4 |
try finding whats holding the throttle wide open? |
| awames76 | Oct 19 2013, 02:25 PM Post #5 |
my old 94 g10 had a bad idle speed motor [up graded emissions] when it went bad it went high idle 4 or 5000 dont remember. unplugged it and had to push the plunger back in. check idle speed motor, as said before check throttle cable. look over make sure nothing in nothing in side throttle. |
2:18 PM Jul 11
