Hard Engine Shake
Topic Started: Oct 20 2013, 08:00 PM (613 Views)
MetroWutWut
Hello.
I have a 97' Geo Metro Lsi. The engine started shaking a couple days ago. It shakes more on turning it on, acceleration and turning it off. It doesn't shake when I coast. It has a small shake when it idles. The shake is like a "massage chair" hard shake. I did notice a little (what looked like) oil under the front part of the engine block, right below where the (also assuming) exhaust manifold is. The distributor cap, plugs, and lines are practically brand new(clean), and the plugs are in the proper firing order.
Could it be a head gasket issue? Or what? :hmm
Thanks.
Stiffchezze
Sir Metrologist
Sounds more like a vacuum line issue. :hmm
You could look for a loose line but I would just go ahead and replace ALL vacuum hoses. About $10 and 20 min of time.
Your in luck! evintho JUST posted the vacuum diagram with pictures!
Link--->Vacuum line routing guide w/pics.
BTW
Welcome! :banana
MetroWutWut
Thanks. :D
I'll give it a check first thing in the morning.
What is the correct firing order for the plug wires?
MetroWutWut
1, 3, 4, 2; Or at least that's what I remembered my mechanic telling me after he did it.
Edited by MetroWutWut, Oct 20 2013, 08:50 PM.
gbreadman
Tinkerer
Check the engine mounts?
Welcome to the forum.
MetroWutWut
Thank you.
How will I be able to tell if the engine mounts are bad/going bad?
gbreadman
Tinkerer
http://www.doityourself.com/stry/5-problems-a-bad-engine-mount-will-cause#.UmSKAVN_Fy0
The engine might seem shifted off-center. My rear one was broken off a couple years ago (the one on the firewall); I just went ahead and replaced them all.
With a three banger it's pretty tough to tell because the engine shakes a lot, even when brand new.
It's very easy to order the incorrect one, so if you do purchase new ones, be careful. They're not difficult to replace; I'd also get new bolts, most of them are grade 8.8 M10's or M8's...but upgrading to 10.9 would be a good decision.
I believe he has the 1.3L 4 cylinder like me. Check the vacuum hose coming from the brake booster, it can cause issues like that.
MetroWutWut
Thank you for all the suggestions(and the link), I'll have a look at it in the morning.
MetroWutWut
The engine mounts are fine and as far as I'm able to tell my vacuum lines are fine(when my mechanic has time, he's going to double check them). However, I did discover where the fluid was leaking from! I'm not sure what this part is(the engine looks like it needs a lot of work)?
pictureThe
Edited by MetroWutWut, Oct 21 2013, 03:11 PM.
