P1510 Code; 1996 metro 3/5
Topic Started: Oct 22 2013, 03:48 PM (1,810 Views)
tonsofun1223
Round One
Pulled this code today and no definition availible. Anyone had this pop up have any info? Thanks
David95237
ECM Back-Up Power Supply Malfunction
tonsofun1223
Round One
do you know what this entails?
David95237
It would be a computer problem
tonsofun1223
Round One
well i kinda figured but can we elaborate
vr4
you probably need a new computer
tonsofun1223
Round One
the car is running and driving fine drove it over 150 miles. no issues at all wouldnt i have some type of malfunction?
vr4
You do. A check engine light and code p1510 stored.
Stiffchezze
Sir Metrologist
While true it *could* be your PCM, that's like number 5 on the flow chart in the FSM.
Lets start closer to the top of that chart. :hmm
Check your 15amp tail light fuse. This fuse also provides 12v to your OBD II connector. If it's blown, you get a P1510. ^o)
vr4
Stiffchezze
Oct 23 2013, 03:28 AM
True.
Except I don't hand information over freely to those who fail to do basic checks. With a power supply malfunction the first thing before starting a thread should have been check all fuses.
Papa_G
Glen. On today's cpu controlled cars, when in for service, I use a 9V battery attached to a battery clip and a cig lighter adapter, Why, you ask? In order to keep the customers radio presets, seat and mirror memory, etc. any time I need to disconnect the battery. It also saves me time (20 to 40 minutes) with the car having to "re-learn" its idle. Check to see if there is a power lead to the PCM that is not providing (backup) power to the cpu when the key is off.
Edited by Papa_G, Oct 23 2013, 01:32 PM.
tonsofun1223
Round One
well fuses were checked already so not that but MAYBE you should assume some people don't know everything and they are on a forum asking because they indeed do not know. No need to reply to people if you aren't giving good info or are withholding info out of spite.. Thanks for the tip stiffchezze.
