engine compatability; 2001 to 1993
Topic Started: Oct 26 2013, 12:26 PM (675 Views)
kayakerjimmy
will a 2001 1.0 hook into a 1993 1.0?
Hotrodray1
Over Educated parts guy
The main long block will fit from a 2001 1.0 to a 93 1.0. intake and exhaust and distributor is different. swap the 93 intake, exhaust manifold and distributor and it should work.
Edited by Hotrodray1, Oct 26 2013, 02:41 PM.
nathan298
Geo Resurrector
The long block will. You will need to re-use the intake manifold, oil pump, and oil pump gasket. Also, the timing belt and water pump belts and pulleys will probably be different, but could easily be swapped.
Edited by nathan298, Oct 26 2013, 02:32 PM.
There's no such thing as a 2001 three cylinder. At least, not according to the manufacturer.
91 ragtop
You don't need to mess with the oil pump or take off the oil pan when putting the newer engine into the older chassis. Just use intake and distributor and use the newer alternator and pulleys with the extra rib belt that the newer ones used to help get away with the common belt squeal problem.
Ken.......
I think woodie is right. Never heard of a g10 in a 2001 model.
