| Rattling noise and trouble starting after Crank shaft seal replace | |
| Tweet Topic Started: Oct 26 2013, 02:50 PM (587 Views) | |
| Phenix | Oct 26 2013, 02:50 PM Post #1 |
Successfully reinstalled cam and crank shaft seals only to notice rattling sound upon acceleration, trouble starting (will turn over then 'waw waw' but eventually starts) and a continual leak. Thinking it is an improperly torqued crank sprocket bolt and/or oil pan. Starter symptoms? Any input appreciated. |
| clarkdw | Oct 26 2013, 04:30 PM Post #2 |
Edited by clarkdw, Oct 26 2013, 04:30 PM.
| Phenix | Oct 26 2013, 05:58 PM Post #3 |
| clarkdw | Oct 26 2013, 06:45 PM Post #4 |
Under torqued and now moving. It will quickly wreck the woodruf key and the crank if not corrected. |
2:17 PM Jul 11
