Need firing order diagram
Topic Started: Oct 27 2013, 01:16 PM (1,248 Views)
Bill2013
Was changing the spark plugs and wires and forgot to diagram the firing order. Here's a diagram--http://autorepair.about.com/library/firing_orders/bl-fo-5384.htm--but I have two at the bottom and one on top perfectly centered between them. That is, the triangle isn't at an angle but rather one and three are level with each other. I assume it's number two on top, but the only reason I'm wondering is because that order makes the wire for three pulled rather tight. Does number two on top sound right?
Edited by Bill2013, Oct 27 2013, 01:16 PM.
http://geometroforum.com/single/?p=685947&t=4464045
Here is a correction of the diagram used in Chilton and Haynes:
