Surging idle is back...but different this time
Topic Started: Oct 27 2013, 01:17 PM (445 Views)
CharlestonMetro
'93 vert LSI with stick shift....
The idle is surging again, but here is what is different this time.
The surging stops when the vehicle comes to a stop. It's like there is some moving part causing the surging that goes away when the vehicle is idling still.
I have checked all the vacuum lines...I can't find a leak anywhere. Any ideas?
Thanks!
sjbene123
i would say tps that is usually the opposite it starts when u stop
Fester9521
Does the engine stumble for a quick second before it returns to idle? I have had a very similar issue with mine, along with a ton of other people. Do the easy/cheap trouble shooting first. Check all of the vacuum lines and also replace the PCV valve. If it is stuck open, it causes a huge vacuum leak causing the idle to "hunt" around. A new PCV valve is about $5 at any local auto store.
Edited by Fester9521, Oct 30 2013, 11:13 AM.
Vkhelldog
When you stop you have your foot on the brake, this is vacuum assisted brake, it changes the vacuum dynamic... it's either a vacuum leak or a sticky idle control valve... try plugging the tiny hole in your air filter, see if that stops it.
Vkhelldog
Is that year an ics or iac?' http://geometroforum.com/single/?p=632384&t=4754158
http://geometroforum.com/topic/4804867/1/
http://geometroforum.com/topic/3279581/1/
Edited by Vkhelldog, Oct 30 2013, 11:29 AM.
