1992 cooling fan trouble.; new fan Switch working But fan not comming on
Topic Started: Oct 27 2013, 06:26 PM (777 Views)
billpinsc
Post #1
- 421
- Group:
- Valued Members
- Member
- #14,315
- Sep 9, 2013
- Location
- South Carolina
- Year/Make/Model
- 1994 3/5
Well today I decided to work on my 92 automatic 2dr. since I got the 94 3/5 I have not been driving the 92. However Before I quite driving it I realized the fan was not coming on. I discovered the old fan was bad. So I went to the JY and picked one up. When I put it in I drove the car until it was well into the higher side of the gauge .Coolant was boiling back into the reservoir so I know it was hot, But the fan did not come on. Next I unhooked the fan from the switch in the thermostat housing and checked to see in the circuit was open or closed. I had reading of 0 ohms when the engine was cool and I forgot to record the reading when hot but the switch was working. I also tried the switch out of my other Metro that I know is good. But the fan never came on. However when I hook the fan straight to the battery it works fine. I don't know what else to check Thanks for any help.
geogonfa
Oct 27 2013, 08:50 PM
Post #2
- 4,318
- Group:
- Tech Certified
- Member
- #2,135
- Apr 6, 2010
- Location
- Hutto, Tx.
- Year/Make/Model
- never too many Verts...
Did you check the cooling fan relay...it should be mounted to the side of the power distribution/fuse box under the hood on the left fender, next to the horn relay and between the battery and coolant reservoir...
billpinsc
Oct 27 2013, 09:14 PM
Post #3
- 421
- Group:
- Valued Members
- Member
- #14,315
- Sep 9, 2013
- Location
- South Carolina
- Year/Make/Model
- 1994 3/5
Yes I checked the relay. I changed it out with the horn relay. The horn worked with both relays.
geogonfa
Oct 27 2013, 10:11 PM
Post #4
- 4,318
- Group:
- Tech Certified
- Member
- #2,135
- Apr 6, 2010
- Location
- Hutto, Tx.
- Year/Make/Model
just out of curiosity, did you jump the temp sensor connector at the thermostat housing to see if the system was working?
billpinsc
Oct 28 2013, 06:05 AM
Post #5
- 421
- Group:
- Valued Members
- Member
- #14,315
- Sep 9, 2013
- Location
- South Carolina
- Year/Make/Model
- 1994 3/5
When I ground the temp sensor the gauge goes to hot. So I assume it was working. When I get home today I am going to jump the connecter to the fan switch to see if it will run.
David95237
Oct 28 2013, 10:06 AM
Post #6
- 2,627
- Group:
- Valued Members
- Member
- #13,795
- Jul 13, 2013
- Location
- lockeford CA
- Year/Make/Model
- 97 3/5.
Sounds like the wrong sensor. one just runs the fan.
billpinsc
Oct 28 2013, 08:01 PM
Post #7
- 421
- Group:
- Valued Members
- Member
- #14,315
- Sep 9, 2013
- Location
- South Carolina
- Year/Make/Model
- 1994 3/5
Well today when I got home I started the car and let it get HOT. Then I unplugged the fan switch in the thermostat housing and I used a paper clip to jump the switch out . I could hear the relay click on but still no fan. ???
Oct 28 2013, 10:01 PM
Post #8
- 9,836
- Group:
- Valued Members
- Member
- #5,381
- May 3, 2011
- Location
- Bay Center, Washington on the Coast
- Year/Make/Model
- 1991 Geo Metro Convertible and 1990 XFI
go directly to the fan. There is a connector there. wiggle the hell out of it. pull it apart and put it back together. wiggle the hell out of it again........
| 1 user reading this topic (1 Guest and 0 Anonymous)
