| crank positioning wire; missing wire | |
| Tweet Topic Started: Nov 2 2013, 07:38 PM (389 Views) | |
| pastorjed | Nov 2 2013, 07:38 PM Post #1 |
wire missing on the bottom of the crank, just a plug their, if i get new wire where does it plug up to on the other end |
| Stiffchezze | Nov 2 2013, 07:49 PM Post #2 |
Sir Metrologist
No such animal on a '95. Sounds like you have a '96 and up OBD II motor in your '95. No problem, just let it be. Post a pic to be sure.
| David95237 | Nov 2 2013, 07:50 PM Post #3 |
If your car is running It doesn't need a crank sensor. only used from 96 on. looks like someone put a newer motor in your car. |
2:15 PM Jul 11
