Engine idle drops after setting for half a minute; Engine power drops
Topic Started: Nov 3 2013, 01:46 PM (657 Views)
BillMan
I start my car, and let it run and after 30 seconds to a minute... The power coming from the engine drops.
I know I'm going threw the whole timing issue, I think it is fixed?
So, what do i do about the power loss from the car idling after so long?
Thanks,
Will
you said two different things: power loss and lower idle.
if its lower idle then maybe you have got the car warmed up and it is going from a cold idle to a warm idle.
mine idles cold at about 1200 rpm--when it gets warm it drops to about 800 rpm
when its warm and I run for a while and pull up to a stop light it drops fairly quickly to 1200 then over about 30 seconds goes on down to about 800
BillMan
Ya, the idle gets lower, on cold stars and warm starts the same way.
Im not sure about that system so I will have to let someone else come in ----fairly simple fix tho im sure
what year is your Geo
BillMan
1990 geo metro Lsi
BillMan
It seems like it drops so low that it may be causing a very, very, very, faint engine ping. but I dont know if it is the engine or the exhaust I'm hearing. As it does have a shake to it.
might check this out"
http://geometroforum.com/topic/4804867/1/
there is also a sensor tht tells it when to go from cold to hot idle. Im not sure where it si---
BillMan
I don't have an RPM gauge, is there any way to find out what the RPM's are and what it drops too?
if you have an autozone or oreilys auto parts maybe they could check.
MPguino--many have them as an addition to the dash. read here
http://geometroforum.com/topic/5063715/1/
BillMan
I looked into Orielys, they do not have a tool to test, no autozone around me however, so can not use them.
David95237
http://www.ebay.com/itm/Digital-Tach-Hour-Meter-Tachometer-Gauge-Spark-Plugs-Gas-Engine-Motocycle-ATV-/161039430085?pt=LH_DefaultDomain_0&hash=item257eb2b1c5
This tack will work for a diagnostic tool.
BillMan
Perfect, thank you :)
Only one wire to hook up? Is it battery operated?
