Little addition to my car.
Topic Started: Nov 4 2013, 08:22 PM (1,749 Views)
chevystrong90
Certified Technician
perfesser
Nov 7 2013, 01:22 PM
You may need a few extra things under the hood to make it function.
I was thinking about that. When I unplugged everything it was just spliced into this harness. What would you think I would need.
perfesser
Well, for starters, you need something to hook onto the throttle to pull it open. Probably vacuum operated. Then you need something to monitor the speed and control it. There must have been a lot of goodies plugged into the harness. Check your FSM to see exactly what they are and go back and get 'em.
Don't check your FSM 'cause there was never any such thing. If it's cruise control, it's aftermarket.
Awesome-X
Yep no factory CC on those models. Only aftermarket.
chevystrong90
Awesome-X
Nov 8 2013, 12:37 PM
Well I did see a black tubular style box that was linked to wires and the throttle body. So I'm sure it was aftermarket now I'm going to go back and make up my own wiring diagram and throttle diagram off the car and hook it up the same waqy I had got it off.
Nappers
ascensions
Nov 4 2013, 09:22 PM
My hatch release is the child in the trunk.
Trunk Monkey!
http://www.youtube.com/watch?v=8avOiTUcD4Y
