| Hood Badge | |
| Tweet Topic Started: Nov 20 2013, 04:52 PM (443 Views) | |
| MechaGodzilla | Nov 20 2013, 04:52 PM Post #1 |
On a '95... Is it attached with double-stick tape or does it have pins that go through the hood? |
| compjake | Nov 20 2013, 05:00 PM Post #2 |
Mostest Elitest Member
Both, or atleast mine was |
| MechaGodzilla | Nov 20 2013, 05:16 PM Post #3 |
Thanks. I don't want to break the thing; what's the best way to remove it? |
| Mythstae | Nov 20 2013, 05:32 PM Post #4 |
It is both. Pins and sticky stuff. You can just stick a small screwdriver under an edge and pry up. Just be careful that you don't scratch your paint. Unless you don't care, in which case, scratch away!
| t3ragtop | Nov 20 2013, 06:05 PM Post #5 |
i use a length of monofilament fishing line to cut the double sided tape as much as i can. then i lift the emblem off with a plastic windshield seal tool. it works best when it's hot. you can use a heat gun or hair dryer to soften the adhesive.
7:39 PM Jul 10
