| Drivers door won't unlock | |
| Tweet Topic Started: Nov 23 2013, 04:02 PM (699 Views) | |
| medicblue | Nov 23 2013, 04:02 PM Post #1 |
Does anyone know a trick to get a drivers door open when the lock won't unlock? 94 Metro hatchback 3 banger, has the automatic locks when you start to drive they lock at 5ish mph. so, can't unlock from inside or with key, I have the panel off enough that I can see the rods and inside of door latch, I have tried gentle prying and working the rods back n forth. I took the passenger side panel off and have been comparing and I can see that the lock seems to be jammed for some reason. I can't see real well because I can't get the panel all the way off with the door closed. there has to be a way, if I can get the door open I might be able to see what the jam is and clear it or bypass it |
| geogonfa | Nov 23 2013, 05:05 PM Post #2 |
Good reading here: http://geometroforum.com/topic/4354046/1/ |
| medicblue | Nov 24 2013, 07:02 PM Post #3 |
ty Geogonfa, I got the door open just a bit ago by trying the key for the 80th redundant time and suddenly felt it turn further, then while holding it all the way over I tried the handle, (something I also tried 10 x yesterday) but the door popped open. Was able to get a better look and saw nothing, the lock started working from the inside as well. What ever the jam was it cleared. So I got it all back together, and D/C'd that auto lock too. we'll see.
Edited by medicblue, Nov 24 2013, 07:03 PM.
| truckjohn | Nov 24 2013, 08:40 PM Post #4 |
First question... Have you ever sprayed any sort of lubricant into your door locks ... to make them work "Better" and all... |
| yiffzer | Nov 24 2013, 09:29 PM Post #5 |
Forgot His Manpurse
Graphite or silicone lubricants would be good. |
| Old Man | Nov 24 2013, 09:35 PM Post #6 |
I spray my window tracks with silicon lubricant each time I change oil. At the same time I also spray all my locks. Been doing this since my 2001 Ford Ranger was new. No Problems yet. |
7:39 PM Jul 10
