dimensions for lower radiator support and frame rails
Topic Started: Nov 25 2013, 04:18 PM (1,282 Views)
Dang nice work! :thumb I've found that body work is a series of technical adjustments. :gamerz Looks like you nailed it. ^o)
For paint, my logic is, and I'm no expert by far, the oe paint is a 2 stage. :hmm Color & clear. :news It made sense to stay with the same automotive grade system for touch up/panel painting. ^o)
Then, when it comes time to paint the entire care, prep work will be reduced. :deal Stripping the old old Rustolium grade, chalk board paint, or what ever awful stuff some use, would be an extreme production to say the least. :oshit
Your car looks fine from here. ;) Way to go after it. :cheers
terry8750
terry8750
yep probably a good idea that when i do paint it hit that sucker with a wire wheel and start fresh with self etching primer followed with high build primer sealer sand it down with some 300 grit hit it with a fresh coat of bc/cc let it dry in the garage .
