headlight adjustment
Topic Started: Nov 30 2013, 02:47 AM (570 Views)
fireflyin
i recently installed a 6000k HID kit on my pontiac firefly and i was wondering how to adjust headlights up "example" turn driver side bottom headlight screw too right too raise? and left to lower? passenger side left to raise n right to lower? em i right about this ? just checking to make sure i got this correct
I don't have a tutorial but do have a tip. When it's dark, park the car on a flat surface 10-15' back from a wall turn on the lights and adjust away. You will be able to see immediately if you are going the right way. Good Luck.
fireflyin
well i did it at a carwash last night and it seemed too help alot mite do some more adjustment later on or leave it since its almost perfect
