down shifting problems
Topic Started: Dec 10 2013, 10:10 PM (650 Views)
craigman
Fellas,
When I come to a stop and try to put it into first gear, it really has a hard time going in. I usually have to put it into 2nd, then into first. It usually takes a few tries.
Any ideas what the problem is and how to fix it?
Thanks!
Craig
Are you completely stopped when you try to engage it? Either way, there's a good chance your syncro is worn.
craigman
Yep, at a complete stop.
patrickbruce
average teenage gearhead
Synchros
craigman
that's what I figured.
Is there any threads or sites that show the process?
patrickbruce
craigman
Dec 10 2013, 10:55 PM
There are several, I'm too lazy to search for them at the moment. Search "5 speed rebuild" .
there are quite a few threads listed here:
https://www.google.com/webhp#q=geometroforum+5+speed+rebuild&undefined=undefined
Let me throw out a few links to see if they help.
Manual Trans Removal /Clutch Guide; How to remove the transmission by Johnny Mullet
DIY Transmission Repair - Part 2 - Splitting The Case by pacapo
Transmission Mission Gears by Jittney
Hold on to your lug nuts, it's time for an overhaul!!!; Rebuilding a 95 by 95-3banger and transmission rebuild starts at post #32.
No 5th gear just RPM's with lots of pics.
The Ratios Thread
How to Determine Your Transmission Final Drive Ratio - In the Car or on the Bench; With Pictures by Wobblybob
94 Metro 5 Speed Manual Transmission Rebuild by DOCTORBILL on Automotive Forums.
CV Joint Replacement
Clutch Adjustment
Parts:
GEO Manual Transmission Rebuild Kits
http://alltransmission.com/ Wholesale only so have someone buy from them for you.
Dec 11 2013, 02:21 AM
Transmission Rebuild[/url] by DOCTORBILL on Automotive Forums.
Good memories. I really miss Doc. Someone should attempt to track him down and see if we can drag him here...if he still has a metro. Might be too many Phoenix es es if he joined though.
Ok, I pm'd him on automotiveforums.com. Maybe he'll get back to me, last activity was in Nov.
craigman
Wow! Great info!
Thanks fellas!
Craig
Yes its tired syncros. I do see Doc logged in here every once in a while.
