I Love New Noises; Rotational "scrape"
Topic Started: Jan 6 2014, 04:36 PM (698 Views)
MechaGodzilla
OK- I replaced my CV axles a month ago and got rid of the dreaded cornering clicks. Now I've noticed a new sound coming from the driver side front; a rotational "scrape" that sounds like a worn brake pad, but it doesn't change when the brakes are applied so maybe not brake-related? :dunno It's not loud, but just noticeable enough to be annoying. :smackface
Ideas anyone?
GeoStalker
Dust shield is rubbing. Just reach in there and bend it out a bit.
Edited by GeoStalker, Jan 6 2014, 04:54 PM.
vr4
+1
MechaGodzilla
GeoStalker
Jan 6 2014, 04:53 PM
Thanks guys! Still a newbie over here. Hopefully I will be able to give that a try this weekend once the temps come up a bit. We hit -12.1 at our place last night, but should be back above freezing on Friday or Saturday.
Freeman
The Family Man
OOoooH! Great thread. I think this solves my issue too. I may have bent the shield while I was replacing a wheel stud. Would explain that noise.
MechaGodzilla
Would a noise caused by a rubbing dust shield go away if you were turning away from it? This is the case with mine; noise from left side goes away when turning right.
don_dowdy
"Would a noise caused by a rubbing dust shield go away if you were turning away from it? This is the case with mine; noise from left side goes away when turning right. "
The dust shield turns with the wheel. Might be a tire rubbing on a loose plastic inner fender.
A little play in the assembly will allow the rotor to move away from the dust shield causing the noise to stop when turning the other direction. It may also get a little louder when turning towards the side it's on.
Freeman
The Family Man
I think I have some scraping on my splash panel too. There is some of it missing and I can hear it on the driver side when turning right. Looks like it is rubbing while turning hard.
davegran
Old Fart w/Wrenches
Buildup of ice and snow in wheel well? :stoner
MechaGodzilla
davegran
Jan 8 2014, 11:38 AM
No, but if it is a bent dust shield, that may have been the cause.
