| Fork Lift; Problems reving with LP | |
| Tweet Topic Started: Jan 9 2014, 04:03 PM (816 Views) | |
| Stompjrkz400 | Jan 9 2014, 04:03 PM Post #1 |
Spent all day working on our old hyster 40 forklift Didt want to start today, and has been not wanting to rev for months Cleaned regualtor and carb/mixer Spent alot of time redoing lines, checking for vaccum leaks Then i found a solution ![]() Completly capped off the airbox, runs like a raped ape Y? Doesnt it need SOME air? I have mechincal skills, but LP is unknown to me Thanks Heres the pretty engine
| vr4 | Jan 9 2014, 04:58 PM Post #2 |
Vacuum leak |
| Memphis metro | Jan 9 2014, 05:01 PM Post #3 |
Put a new bottle on it. Is the bottle installed correctly? Is the valve opened fully? |
| Stompjrkz400 | Jan 10 2014, 12:48 AM Post #4 |
Yes new bottle ( old one same results) pressure all the way to the carb. But i dont know how much pressure |
| Freeman | Jan 24 2014, 06:53 AM Post #5 |
The Family Man
I would say it's a vac leak also. That would be the only reasonable way for it to run better like this. Try the old carb cleaner trick to find a vac leak. |
| sphenicie | Jan 24 2014, 07:56 AM Post #6 |
too much air, too little fuel. I only have a vary little time with LP, but I do not believe that there is any vac system involved in fuel delivery. it is a positive pressure gas (as opposed to liquid) delivery system. my first thought would be the regulator. is this a duel fuel system? if so, your crossover could be involved. ie; system is mixing for gasoline not for LP. |
| Murf 59 | Jan 28 2014, 03:01 AM Post #7 |
Regardless of how the fuel gets in it, it can't run with to much air. If you can plug off the air cleaner and it does run then, it must be getting it somewhere else. Try the carb cleaner trick to find the air leak.
![]() Our users say it best: "Zetaboards is the best forum service I have ever used." Learn More · Register Now |
2:26 PM Jul 11
