| clutch making a slight grinding noise in reverse; clutch making a slight grinding noise in reverse | |
| Tweet Topic Started: Jan 13 2014, 07:07 PM (614 Views) | |
| djflip81 | Jan 13 2014, 07:07 PM Post #1 |
I just got a tune up, new exhaust, new cats, oil change, seals, gaskets, and some other stuff as well. Before all of that never heard this noise when going into reverse. Does anybody know whats going on.....i think my clutch is fully engaging for some reason....again everything thing else is smooth and its only making that noise slightly? |
| Johnny Mullet | Jan 13 2014, 07:22 PM Post #2 |
You did not state what year or what engine, but if you had exhaust work done, check there first. It might be hitting the swaybar, floorboard, shifter, etc The engine tilts forward under load in reverse pushing the exhaust backwards. |
| djflip81 | Jan 13 2014, 07:29 PM Post #3 |
Im sorry....i have a 97 geo 1.0 5 speed....im shoot that across to my mechanic tomorrow when i see him |
| djflip81 | Jan 13 2014, 07:36 PM Post #4 |
if it is hitting something...can it be adjusted...what would be the fix for that? |
| socal geo garage | Jan 13 2014, 11:10 PM Post #5 |
drive it back to the muffler shop with your receipt and they should adjust the muffler free. |
| Murf 59 | Jan 14 2014, 11:41 AM Post #6 |
If it is hitting yes it should be adjusted where the work was done. The noise your hearing is it not quite wanting to go into R. The clutch is not quite releasing enough. Its a square cut gear. So its where a tire clutch problem shows up. |
2:14 PM Jul 11
