| Gear oil specs | |
| Tweet Topic Started: Jan 15 2014, 02:46 PM (2,082 Views) | |
| djflip81 | Jan 15 2014, 02:46 PM Post #1 |
What gear oil do I need for my 97 1.0l 5 speed geo metro? I sort of struggle to shift nad im hoping this gear oil change will help.....i see you guys says pennzoil synchromesh but im not sure what weight?....also has anybody tried lucas? |
| patrickbruce | Jan 15 2014, 02:53 PM Post #2 |
average teenage gearhead
pennzoil synchromesh. Works the best so far
| Stiffchezze | Jan 15 2014, 03:04 PM Post #3 |
Sir Metrologist
Just synchromesh. It only comes in one weight. |
| Napolean Drivinglight | Jan 15 2014, 03:11 PM Post #4 |
Bent Wrench Garage
Syncromesh for the win. My Metros trans now shifts so smooth it makes butter wish it was that buttery. Edited by Napolean Drivinglight, Jan 15 2014, 03:12 PM.
| myredvert | Jan 15 2014, 03:58 PM Post #5 |
Synchromesh has worked wonderfully for me the last 12 years in both my Metros and Tracker. It's a little pricey, but its guuuuuuuuuuuuuuud. Thankfully the Metro doesn't have a front diff, rear diff, transfer case, and transmission to fill like the Tracker had. Glenn has mentioned using "regular" synthetic oil, but you would have to check with him on specifics for weight/specs. Come to think of it, my Scott's (John Deere) garden tractor uses synthetic 5W20, and it's gearbox isn't that much smaller than the Metro's! |
| heckling7 | Jan 16 2014, 11:01 AM Post #6 |
I'd have to say if there was one fix that reflected the best result it was folks on this forum suggesting Synchromesh My 3/5 97 was not smooth shifting nor easy when I first got it after two previous owners. I dumped the old stuff which was probably the original lube after 82k from the factory and it was nasty with a lot of gold flakes. The synchromesh is a delight to shift and almost too easily. Even in sub 0 weather it shifts nice. I'm on my 2nd change of it as I change it out around 40k. For 3 $8 bottles its well worth it. You only need 2.5 quarts. Make sure you can remove the fill bolt first. Blast it with PB Blaster over several hours or a day. Reading some past posts I may try a GL-4 Synthetic motor oil in my tranny next time, due to the lesser cost. Edited by heckling7, Jan 17 2014, 10:36 AM.
2:14 PM Jul 11
