| Swift GT Parts on a 92 Convertible Metro; Parts Adaptability | |
| Tweet Topic Started: Jan 18 2014, 07:35 PM (985 Views) | |
| Geo ji | Jan 18 2014, 07:35 PM Post #1 |
I have a 92 Metro Convertible and I am going to try to put a 91 swift GT front bumper and side skirts on it. I need to see what other parts I will need to make this mod work. What kind of problems should I expect? Thanks. Steve |
| 94RHDRollerskate | Jan 18 2014, 08:18 PM Post #2 |
Forum Stud Muffin
Front bumper and side skirts should be able to be installed without any problems. May have to also have the inner bumper mount if different from '91 and '92 (I'm unsure). Mounting the side skirts will require 6ea of the mounting clips and drilling 6 holes into the body to do it right. |
| CAMI MAN | Jan 18 2014, 09:14 PM Post #3 |
Hi Steve I think you will need the 91 foam backing for your 92 bumper and for your side skirts it is nice if you have the steel rocker rail from the GT as well . |
| 94RHDRollerskate | Jan 18 2014, 09:28 PM Post #4 |
Forum Stud Muffin
Steel rocker rail is nice, but will require welding to the car. All depends on how far you want to take the mod. |
| CAMI MAN | Jan 18 2014, 09:45 PM Post #5 |
It helps the plastic from sagging and bowing . Easy to mount drill 3 holes and use screws to mount .
| 94RHDRollerskate | Jan 18 2014, 10:06 PM Post #6 |
Forum Stud Muffin
If one can locate one tat's not ate up with rust, and successfully make the surgery over from the donor car. I attched mine with self-tappers the length of the rocker. Rail would be best though if doable. |
| Geo ji | Jan 18 2014, 11:13 PM Post #7 |
Thanks for your help. Will I be able to retain the stock headlights with the GT bumper? |
| Hotrodray1 | Jan 18 2014, 11:22 PM Post #8 |
Over Educated parts guy
Yes |
| punkozuna | Jan 19 2014, 01:00 AM Post #9 |
Post some pics as you go! |
| razr769 | Jan 19 2014, 01:14 AM Post #10 |
Got boost?
To specify, you can keep the geo headlights if you use the metro upper bumper cover. The gt upper bumper cover has the grill so you need to switch to a swift hood and headlights if you want to use it. |
7:38 PM Jul 10
