popping sound and constant rubbing/grinding sound
Topic Started: Jan 20 2014, 02:32 PM (1,361 Views)
Mrbreeze
I been having a similar problem with my 93, replaced axles, bearings,one hub with a new one from dealer, about once a year my hub will start rubbing on the knuckle and I have to remove wheel, caliper,pads, get the rubber mallet out and rotate the hub and beat the rotor till its centered or past the the cutaway for the pads. Only on the one side, passengers side no problem. Anybody have any ideas? The same side that has the new hub.. :banghead
Edited by Mrbreeze, Feb 16 2014, 09:01 PM.
