96 Metro CLUTCH NOT DISENGAGING; New Clutch not working
Topic Started: Jan 28 2014, 08:34 PM (1,530 Views)
geogonfa
when the lever is out of position it will act just as you described...like there is no spring tension...
David95237
Jan 29 2014, 10:58 AM
Did you have any problem installing the transmission, was it hard to slide on. or did you have to draw it up?
:gp
Giared
When I originally re-installed it I did align the reference marks. I then advanced it one spline to get more pedal, still the clutch would not disengage.
Giared
Jan 29 2014, 04:19 PM
I am pretty sure you would have to retard it.
BobJ
New throw out bearing identical to old?
