| popping out of 5th gear; manual tranny pops out of 5th gear. been in it 3 times... | |
| Tweet Topic Started: Feb 3 2014, 01:46 PM (1,094 Views) | |
| 1slowride | Feb 3 2014, 01:46 PM Post #1 |
ok, i have a 89 metro, 5 speed manual tranny. this thing refuses to have a 5th gear, lol. i have been in it 3 times.. checked & double checked everything & still no 5th gear. when it started popping out i took off the black cover & found a worn shift fork. replaced that, put it back together & still no 5th. sooo.. i took it off again, checked the high speed hub, everything looked good, good keys, good springs, ect. checked the phillips screws on the flat plate behind the gears, (which i had forgotten to do previously), they were tight, so i put it back together... again.... still no 5th. took it apart the 3rd time, very carefully checked everything, made some adjustments & put it together again... (this damn thing has a mind of it's own im tellin ya) !! so... im at my wits end is there anything inside the main housing that helps keep it in 5th ?... such as a ball & spring on the shaft or something ? my next step is to try to find a new gear & hub, since there is a little wear on the teeth (dont look like enough to make it pop out of gear but what do i know) is there somewhere that these can be bought ?... if so, any idea of the price ?... i refuse to go into it again until i know more than i do at this point.... by the way, i did put it in gear with the cover still off... looked like it was working perfectly... i really need help... (no psychiatrist jokes please lol.. i already know im insane),
Edited by 1slowride, Feb 3 2014, 01:55 PM.
| bansheetaz | Feb 3 2014, 03:09 PM Post #2 |
make sure your motor mounts arent broken. also check the linkage for looseness. |
| 1slowride | Feb 3 2014, 04:07 PM Post #3 |
motor mounts seem ok, rubber isnt broken or anything. i have read several places that when they get old the rubber gets soft & can cause this problem. is there an easy way to check them ? i mean i could try shaking the engine but i dont know how much (shake) is normal...im not financially able to spend much on troubleshooting. as for the linkage there is no slack, rubber bushings are good. she shifts like a new car other than the 5th gear popping out. im pretty sure it's a transmission problem but cant rule anything out. thanks for the input bansheetaz. |
| 1slowride | Feb 3 2014, 05:37 PM Post #4 |
UPDATE, i found the spring & ball that is on the 5th gear shaft in the transmission... thats not the problem. i put a little more pressure on the spring & that didnt hold it in 5th gear... back to square one......... looking for a new gear & hub sleeve unless someone has a better idea. and no, im not putting a bunjie cord on the shifter to hold it in... dont wanna change another shifting fork, lol |
| Murf 59 | Feb 3 2014, 06:23 PM Post #5 |
Have you tried unhooking the linkage to the trans and shifting it that way? Is it just not selecting, or is it jumping out? |
| pdqrunner | Feb 3 2014, 07:14 PM Post #6 |
Did you read this thread http://geometroforum.com/topic/4302477/1/ |
| 1slowride | Feb 3 2014, 10:24 PM Post #7 |
hey mr murph. no i havn't disconnected the linkage but it's shifting good into 5th gear.. i checked it with the cover off & also by driving it. what its doing is going into gear fine, then popping out after a few seconds of acceleration. when doing the driving test, i put my hand on the shifter very lightly so as to feel what it was doing without holding it in gear. what i felt was, it stayed steady for a few seconds, then i slowly felt the shifter pushing back toward neutral, until it finally popped out of gear. are new parts available for this car ?...im pretty sure i need the 5th gear & the sleeve/ slider that the fork pushes in, as the teeth on both parts are all worn about 1/4 of the way where they meet on the sides.. the ends arent worn much... whats your opinion on this ? im not sure how much wear is common on these. |
| 1slowride | Feb 3 2014, 10:28 PM Post #8 |
yes i did thanks. it sounds kinda like what im thinking about mine.... i probably need a new gear & slider/sleeve. read the post above, that i answered to mr murph & if you have any opinions please let me know. also let me know, if you know if new parts are available for this old car |
| David95237 | Feb 3 2014, 10:30 PM Post #9 |
http://www.gmpartsgiant.com/Page_Product/PartDetail.aspx?Make=Chevrolet&Model=Metro&Year=1997&MakeCode=C&ModelCode=M&CatalogCode=15M&tCode=M58&mCode=1MR08&majorIndexID=04&SupplGroup=50&minorIndexID=SU04-097&SortKey=3 They are even on sale. #13 and #19 Edited by David95237, Feb 3 2014, 10:32 PM.
| Metromightymouse | Feb 3 2014, 10:38 PM Post #10 |
Yep, that's it, the part that is gone allows the gear to walk off. Doesn't take much to allow it to pop out of gear. When done, be sure to put 2 1/2 quarts in. If the car is at an angle it is easy to under fill the trans and 5th depends on the oil coming in through a hole at the top. If it's not full you starve it for oil. Don't ask how I know... |
| 1slowride | Feb 4 2014, 05:49 PM Post #11 |
hey david, thanks for the link... problem is, i cant afford almost $200.oo to have 5th gear right now. anybody know where i can get cheaper parts ? if i could find a used gear & sleeve with little to no wear, i'd settle for that. |
| 1slowride | Feb 9 2014, 11:32 AM Post #12 |
hey, found a gear & slider at a junk yard... so far 5th gear is holding in place. thanks for all the help guys
| David95237 | Feb 9 2014, 11:41 AM Post #13 |
Glad you got it fixed. |
| Metromightymouse | Feb 10 2014, 04:53 AM Post #14 |
Amazing what having all your teeth does for how |
2:14 PM Jul 11
