Anyone with mitchell ondemand access?; Technical information
Topic Started: Feb 13 2014, 01:03 PM (946 Views)
Looking for someone with mitchell ondemand access or alldata to give me specific information. Anyone?
Jordan
Like what?
I do have access.
I was trying to find the fuel relay location and fuel pressure specs for a 92 nissan maxima. I found the relay located in the trunk but it is located with another relay. One is green and one is orange. Now I need to know which is the fuel relay and what the other relay is.
According to this that I found online it is the orange relay. That just does not seem right to me considering most fuel relays are usually green. I hate trying to google something like that.
Jordan
Mitchell says it's the green one. LS of trunk, near taillight.
Should be 4 wires - 2 blue (fused power), 1 red/blue (feed to fuel pump), 1 blue/white (ground side).
Fuel pressure specs - 36psi @idle, 44psi @idle with vacuum supply removed from pressure reg.
Hope that helps.
Edited by Jordan, Feb 13 2014, 11:44 PM.
Thanks for the confirmation and your time. It does help.
passons
I found 4 Mitchell Ondemand , but not sure if they are the one you finding, just have a look: http://www.obd2life.com/index.php?main_page=advanced_search_result&search_in_description=0&keyword=mitchell+ondemand
