led flasher
Topic Started: Feb 21 2014, 05:51 AM (484 Views)
bikeAmusPrime
So I was poking around for a led flasher for my ebay KART of led bulbs. I have never pulled a flasher out of my car but I do know that from research out flashers are smaller then the standard size. So I found this one with a socket plug that comes with it so you dont have to brake off tabs that hold the original one in. Im still in the shopping of everything. I have a huge list of leds to cover all of the outside bulbs.
So what I am getting at is to see what you guys think of this?
http://www.ebay.com/itm/3-Pin-CF13-CF14-LED-Flasher-Relay-For-Turn-Signal-Lights-Hyper-Blink-Flash-Fix-/141010663755?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d4e3f94b&vxp=mtr
That should work. It might bang around a bit if you don't tie it down.
bikeAmusPrime
is that the correct one to use?
I checked Rockauto and they showed a 3 wire flasher for your year so it should be right. The wiring diagram should be on the side of the one you remove, just be sure to match it with the wires coming off of the new plug.
My LED flasher fit without modding or adding wires. I'll try to find my spare and post a picture.
perfesser
PO put LEDs everywhere he could on my car, so my turn signals ran at double time. I pulled the OEM flasher and stuck in a Tridon EP-34 I got at McParts. Had to file down a couple of nubs on the side of the new flasher, but it fit right in and works fine.
Case closed (for me, anyway!)
bikeAmusPrime
Thats what im trying to do. Put all led on the outside for now, and later I will deal with the stuff on the inside. Even the wiper and headligjt switches. Im looking at some samsung chipped led bulbs.
