half shaft loosely locked in transmission
Topic Started: Feb 22 2014, 03:19 PM (1,026 Views)
vr4
The transmissions are interchangeable. The 95+ axles are longer due to the wider chassis.
Pull the axle and compare it to the old one.
socal geo garage
You should match them up before you install , match new to old side by side. if its the same slide in the trans side and hit the end with a mallet or 2 by 4 to lock into place and call it done. double check / torque all strut and suspension points and wheel lugs.
Edited by socal geo garage, Feb 23 2014, 03:53 AM.
