can I do this????
Topic Started: Feb 24 2014, 11:13 AM (469 Views)
flea
Hi Guys.....
Well...the Cleveland winter we are having was just too much for my 98. Saturday I pulled out of my driveway and my left wheel went up into the wheel well and my right wheel went out and to the right. :die . I managed to get it back into my garage where it sets. All that was holding the front end together was the brace I made.
Now the questions....
I have found a 92 metro and I was wondering if I can transfer my control arms and suspension from my 98 metro 2-door over to it. Both front and rear. Also, can I change the brakes and wheels over? I believe my front and rear sway bars should switch over as well. My engine and trans should fit. But I believe I have to use the 92 manifold. I think.
Also it is an automatic and want to change it to a stick shift. I have my whole 98 metro and I believe the trans and shifter parts should fit as well. I know it is work but I don't mind that.
Am I wasting my time???
I hope not because this car is from down south with solid frame horns.
Everything should swap over to the older model.
flea
thanks alot
You're going to need different control arms, 98 is wider.
Other than that, you should be good.
