01 Ignition key barrel removal?
Topic Started: Feb 25 2014, 03:19 PM (557 Views)
490k
Here's something I haven't had the pleasure to deal with, until now.
Tried looking online for instructions but could only find older models. Need to pop the barrel out to clean/grease.
truckjohn
Not an easy job. It's not like a Ford where you push the pin, turn the key and piull the whole lock out....
Try dry lock graphite.
490k
Where is the pin location? I tried a pic in the 2 spots nearest the face of the lock. One directly under the lock at 6:00 and another one off to the side, closer to the steering wheel, like a tube sorta.
truckjohn
You have to drill them out
490k
Not following. It doesn't have the small screws like the older cars.
Here's the points I tried using a pick
geogonfa
I have had the pleasure of doing quite a few of these for rekeying...start here, good reading:
http://geometroforum.com/topic/4912705/1/
:type
490k
Thanks. Got it. Pulled the airbag, wheel and column switch, was able to drill out the 2 roll pins from there.
There wasn't any snap ring on mine.
