Axle boot replacement
Topic Started: Mar 11 2014, 10:13 AM (341 Views)
3220onr
So I ripped open the passenger side axle boot when replacing the strut. What is the best way to just replace the boot? I looked at the shaft removal guide but it did not mention just boot replacement. The boot is only costing me $7. Fire away metroheads. I need the help. Thanks
Do you have just the boot or do you have the boot kit? If you have just the boot and it is not split then you will have to remove the axle to put the boot on.
A kit will consist of a split boot, two clamps and some glue. ---- the kit comes with instructions. Check with autozone, oreilys, napa, or your local auto parts store.
3220onr
I just have the boot, two clamps and grease.
pdqrunner
http://geometroforum.com/topic/4691320/1/
