coolant temp gauge; not working
Topic Started: Mar 12 2014, 12:29 AM (400 Views)
freegeo
I have had an issue with the coolant temp gauge not working since I bought the car a year ago. I have worked on the problem with the help of some of the people here. I have found out that I had two problems.
The coolant temp sensor was bad and my temp gauge also doesn't work. The temp sensor I have already changed but i need help with the gauge.
I need to know if the electrical part behind the gauge face can be tested and fixed. It looks like this.
It has 3 resistors on it but I haven't tried checking anything yet. I had a extra cluster and the gauge works (atleast went straight to full hot position). That's how I now this one doesn't. Any help would be appreciated.
ranger88den
If you don't have any luck, I have this for sale on ebay. Everything worked when removed.
http://www.ebay.com/itm/1996-Geo-Metro-Instrument-Cluster-from-a-1-3-4-cyl-auto-trans-2-dr-hatchback-/271412334241?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f316f8ea1&vxp=mtr
freegeo
thanks but i already have one. i like the cluster with the tach. i have. dont want to give it up.
