| Oxygen Sensor; Is it needed? | |
| Tweet Topic Started: Mar 26 2014, 07:40 PM (767 Views) | |
| Bluebomb | Mar 26 2014, 07:40 PM Post #1 |
Okay I have a quick question. First off I have a 1993 four door hatch back 5 speed. When I did my rebuild about 6 months ago I forgot to replace or clean the oxygen sensor and it looks to be slap covered with buildup. I still get around 45 mpg and no codes. Is the sensor really needed? Before the rebuild I was burning about a quart every 200 miles this went on four 3 months before I had enough money to buy what I needed for the rebuild. |
| patrickbruce | Mar 26 2014, 09:18 PM Post #2 |
average teenage gearhead
No code? I wouldn't worry about it, especially if you're getting those kind of mpg's |
| Bluebomb | Mar 26 2014, 10:32 PM Post #3 |
Okay thanks for your advise it is appreciated |
| Hanuman | Mar 27 2014, 02:14 PM Post #4 |
a bad 02 sensor doesnt always throw a code. o2 sensor is cheap.......it may bring you up to 50 mpg, it may change nothing. |
| JADEDSL2 | Mar 27 2014, 07:23 PM Post #5 |
Resident WraithSlayer
02 sensor is necessary. It's how the computer reads your A/F R and adjusts fuel input accordingly to maintain proper A/F R. Now, do you need a new one? Maybe, maybe not. Like pointed out above, bad sensors don't always throw codes. Sometimes you can feel your acceleration "bucking" at low speed, part throttle, and that indicates a bad sensor. Sometimes not. It really varies car to car, and driver to driver. Even on identical cars, the results are not always the same. However, no new sensor ever hurt anything. So if for nothing more than peace of mind, replacing it could never be a bad idea. Just depends on if you want to spend the money or not.
| Geo Pete | Mar 27 2014, 09:56 PM Post #6 |
The two-wire ones are cheap, and when I replaced mine I got a HUGE MPG increase, even though the old one wasn't throwing a code. |
| iveyjh | Mar 27 2014, 10:44 PM Post #7 |
I haven't ran a o2 sensor for 3 years but I do monitor afr with a wide band to set it up on a load based open loop system, otherwise get another o2 sensor, they're cheap. |
| Hanuman | Mar 28 2014, 01:57 PM Post #8 |
can you elaborate more on this please? |
| JADEDSL2 | Mar 28 2014, 02:31 PM Post #9 |
He's saying he's running some kind of custom fuel control. For you, your car is stock, and needs an 02 sensor. Unless you're gonna follow his lead and go custom yourself. |
| Bluebomb | Mar 30 2014, 09:43 PM Post #10 |
I will get me an o2 sensor just to have piece of mind. I really hope it will boost my mpg even if its just by a few. |
| 2000Firefly1.3L | Mar 30 2014, 10:36 PM Post #11 |
a black coated sensor is normal |
| Hanuman | Mar 31 2014, 02:48 AM Post #12 |
i already know that silly..... im asking about his load based system. i want to know what he did, how he did it, and how well it works for him. |
| iveyjh | Mar 31 2014, 10:46 AM Post #13 |
I use an Apexi Safc air/fuel controller with an aftermarket FPR (ebay). Properly set up it will keep your afr at any ratio you want at any rpm and load. It only does afr not timing, I wish it did. One day I will get a piggyback ecu or try a stand alone megasquirt. It keeps my afr correct even with a turbo. |
7:58 PM Jul 10
