Just ordered this cat-back exhaust on Ebay
Topic Started: Mar 29 2014, 12:03 PM (2,349 Views)
pvr007
If you lift the car enough and remove rear bumper you should be good.
orfeo
SUCCESS!!
Just installed the exhaust system:
1. Removed the rear sway-bar/stabilizer-bar (6 bolts) in about 4 minutes.
2. RePainted exhaust w/2,000 degree FlameProof header paint in about 10 minutes.
3. Removed the old exhaust & installed the new one in about 10 minutes.
4. ReInstalled the rear sway-bar in about 4 minutes.
Entire job DONE in about a half-hour!
:rocker
orfeo
Car is running smooth & quiet! Total cost about $100. ($90 for the exhaust + $10 for the header paint)
Did not need to remove the rear bumper, the coil spring, or the shock absorber. . . and did not need to cut either the old exhaust or the new one. From the catalytic converter rear-flange all the way back to the tip of the tailpipe, it came out and went in as one piece.
Edited by orfeo, Apr 10 2014, 01:27 PM.
orfeo
MANY THANKS to idmetro & to Stiffchezze for the winning guidance!
Congratulations on your success! May you enjoy the new muffler for years to come.
Stiffchezze
Sir Metrologist
:thumb
wiredawgg1
Awesome! Good on you! Thanks for sharing. Where did you get the paint?
Edited by wiredawgg1, Apr 10 2014, 07:58 PM.
orfeo
wiredawgg1
Apr 10 2014, 07:57 PM
Advance Auto Parts
http://shop.advanceautoparts.com/p/vht-paint-flameproof-flat-aluminum-11-oz-aerosol-sp117/7141565-P
wiredawgg1
:rocker
Pulling the Trigger!
Edited by wiredawgg1, Apr 10 2014, 08:35 PM.
94RHDRollerskate
Forum Stud Muffin
Sound clip / vid???
Cyborg
McDumbass
Its been a few weeks, are you still happy with this exhaust? How does it look and sound? How was the fitment? I am considering replacing mine and for $90, I might just do it...
wiredawgg1
Yea, I ordered the same thing for my 93 2door. I found this unit to have too large of hanger nobs for standard hanger rubbers. Had to cut them off -they are solid stainless. (extra 30 mins.) Add to that, paint needs to settle, so I painted one night and let cure overnight. Ready to lower the control arm and install the one piece unit........stand bye for updates........
