| Getting electrical shocks constantly | |
| Tweet Topic Started: Apr 13 2014, 11:51 AM (287 Views) | |
| yiffzer | Apr 13 2014, 11:51 AM Post #1 |
Forgot His Manpurse
92 Geo Metro. Began noticing this after I had the common headlight issue where one headlight becomes very dim. I brought it to a mechanic do a quick headlight fix by wiring the left headlight to the right headlight. Mechanic told me I likely had a bad headlight switch (I don't think so). Then afterwards, my headlights began having problems -- flickering -- causing the fuse to constantly break to which I discovered was a loose fuse box underneath the driver side dash. I think the mechanic didn't tighten it down very well. Ever since the headlight had that quick fix and I tightened down the loose fuse box, I kept feeling electric shocks every time I touch anything metal on the car. Mind you, I don't always get the shocks but when I do, it really annoys me. I think it's a grounding issue as the electricity has nowhere to go except to me. Where do I start? |
| Hanuman | Apr 13 2014, 02:00 PM Post #2 |
static electricity builds up on car......you make a better path to earth ground than your thick rubber tires do. circuit complete! sucks doesnt it? its hit me about 5 times in the last week. |
| mwebb | Apr 13 2014, 04:41 PM Post #3 |
FOG
mist a little water from a spray bottle to your LF seat before you get into the car IF that does not resolve the issue connect an electrolytic capacitor negative side to ground / earth / steel / copper pipe in the actual ground / dirt / earth positive side to your car's battery negative use a DVOM measure from your battery negative to the pipe in the ground across the electrolytic capacitor should be zero if there is a value then post the actual value here |
9:12 AM Jul 11
