| wire ID help; a wire!!!!! | |
| Tweet Topic Started: Apr 18 2014, 12:39 PM (344 Views) | |
| redsilver21 | Apr 18 2014, 12:39 PM Post #1 |
so I am working on this geo.. its a 91 3 cyl, 5 speed has AC *idk if that matters but o well..* so there is a wire cut in half and capped off at both then ends *weird counting its location.. but ..* the wires locations its on the front of the engine block , appears to be a sensor , and directly above the oil filter , and all most right beside the motor mount by the timing belt / chain, ready , set .. and go.. I think its the oil pressure sensor..
Edited by redsilver21, Apr 18 2014, 12:42 PM.
| freegeo | Apr 18 2014, 12:53 PM Post #2 |
Does it look like a factory type of wire? Are both ends of the wire the same color. What is the color of the wire and does it have another colored stripe on it? A picture would help. |
| redsilver21 | Apr 18 2014, 12:58 PM Post #3 |
yea factory wire, same color |
| David95237 | Apr 18 2014, 01:07 PM Post #4 |
the only wires over their are for the A/c, O2 sensor and oil pressure down by the filter. |
| redsilver21 | Apr 18 2014, 05:36 PM Post #5 |
next question, my temp gauge doesn't work, autozone doesn't have the temp gauge sensor, is the duralast coolant sensor a match? |
| freegeo | Apr 19 2014, 07:52 AM Post #6 |
Yes the coolant temp sensor they have listed should work. I don't have a older model like yours. If i remember right your engine has a sensor for the gauge and another sensor for the ecu and fan control. If the gauge doesn't work it can be either the gauge itself, the wiring, or the sensor. |
9:12 AM Jul 11
