| Downsteam O2 sensor bung size; Gotta plug a bung hole | |
| Tweet Topic Started: May 2 2014, 10:04 PM (581 Views) | |
| LeoGeo | May 2 2014, 10:04 PM Post #1 |
Ordered a new cat for my 95 and it arrived with a bung port for a downsteam O2 sensor. I just need to know what size & thread the downsteam bung is. I found a M18x1.5 bolt on ebay but i'm not sure it'll fit. Does anyone know of a local source for bolts of this size? Hardware stores have been a strikeout so far. --edit-- Turns out they are readily available for about $3 at most auto parts stores. Just needed to search for "m18 plug" M18x1.5 fits perfectly Edited by LeoGeo, May 11 2014, 05:20 PM.
| Hotrodray1 | May 2 2014, 11:29 PM Post #2 |
Over Educated parts guy
If all else fails pick and pull old o2 clip wires and install. |
| JellyBeanDriver | May 3 2014, 12:43 AM Post #3 |
Junkyard O2 sensor? Or an old one you have laying around? Might be easier to find than a bolt. |
| Metromightymouse | May 3 2014, 06:47 AM Post #4 |
Might check and see if any spark plugs you have kicking around fit it as well. |
| 91 ragtop | May 4 2014, 10:16 AM Post #5 |
Most sparkplugs are 14mm. I think the bung is 18mm but I'm not sure of the pitch. I'll go and see if I can find my bunghole thread chaser. Yep! It's a 18x1.5 Ken.......... Edited by 91 ragtop, May 4 2014, 10:29 AM.
| Joe Dirt | May 4 2014, 10:19 AM Post #6 |
18mm o2 plug, old o2 sensor , 13/16 spark plug (18mm) or weld it up |
| Cyborg | May 31 2014, 08:39 PM Post #7 |
McDumbass
i pull the pipe off, welded a plate over the hole and zip tied the sensor to the car. |
| cwatkin | Jun 3 2014, 06:19 PM Post #8 |
The M18 plugs can be bought in the automotive hardware (drain plugs) at most farm and home type hardware stores. A big store like Lowes or Home Depot probably will be a no go but a small rural store will be a better bet. I have bought these for this exact purpose. I had an older carbed Jeep and all the exhaust manifolds you can find currently have the O2 sensor hole so I needed to plug this up. Conor |
7:58 PM Jul 10
