| Car no start; Positive battery cable | |
| Tweet Topic Started: May 7 2014, 11:46 PM (269 Views) | |
| evadfa | May 7 2014, 11:46 PM Post #1 |
Got in my car the other morning, and put the key in. Got the normal beeping from having the key in. Turned it over and nothing. I started by jiggling the battery cable and it started beeping again because I had the key in and the door open. Went to turn it over and everything went dead again. I took the positive battery terminal loose and cleaned it really good. Long story short, I ended up having to strip the shield and cut the copper off about half an inch on the engine wiring harness to get good copper. Does anyone know why I am getting this corrosion? this is the second time I have done this in about 4 months. What I had hooked up to the positive lead is the wiring harness, fog lights, and a phone charger. Is there something wrong electrically for the car to get that much corrosion? |
| idmetro | May 8 2014, 12:12 AM Post #2 |
I'd check/clean all the grounds in the engine compartment. Secondarily, how old is your battery? The older a battery gets the more it seems to outgas and corrode. |
9:12 AM Jul 11
