| replacing doors? | |
| Tweet Topic Started: May 8 2014, 08:33 PM (313 Views) | |
| academyhill | May 8 2014, 08:33 PM Post #1 |
Can you guys tell me if the doors from a 96 two door hatchback fit on my 93 two door hatchback? I found a really nice set at the PNP and I have to replace the driver side regulator on my 93 anyway. Can I just swap the doors? I know they are different generations but I am hoping they are the same size. I would get the seat belts from the 96 and swap them over to the 93 also. The seats are really nice in the 96 too but I was hoping to score some Esteem seats later. Thanks. |
| macuserman | May 8 2014, 08:35 PM Post #2 |
Nope won't fit. You'll have to hunt down some 94 or earlier doors. |
| macuserman | May 8 2014, 08:37 PM Post #3 |
The seats will fit perfect though. I think the seat belts will as well, you'll probably have to move the to be column mounted instead of door mounted though. Which is a huge improvement if you ask me.
Edited by macuserman, May 8 2014, 08:38 PM.
| academyhill | May 8 2014, 08:44 PM Post #4 |
thanks, I'm thinking about the seats and the seat belts. I did not think the doors would fit but I wanted to confirm with the GMF. thanks. |
| macuserman | May 8 2014, 09:19 PM Post #5 |
Hold out for different seats if you want to, but if you have the in the door seat belts just do it!!! Column mounted seat belts are waaay better. Pretty sure there is a tutorial floating around somewhere on just how to make that change as well.
7:14 PM Jul 10
