Gas tank sending unit; are they all the same?
Topic Started: May 12 2014, 07:58 PM (401 Views)
geometromaniac
My recent purchase 1992 Metro convertible with 68000 original miles has a problem with the gas tank sending unit. It is not the dash gauge. It is stuck at 1/4 tank. Will a unit from a 1998 Metro fit it? How hard is it to remove the gas tank I havent done that before. What year cars can I get a sending unit from. The local junk yard only has 1996 and later Metros no early ones. Any help will be greatly appreciated.
Will not work. Differant design. The later model has a fuel sender by itself while the vert has its built into the pump assembly. I have a vert sender I might swap you for a good sender out of a 95 or later model if it is the same as mine. Here is mine out of a 95. 96 and later should be similar to this one.
http://geometroforum.com/topic/5400925/1/#new
The square one posted in this thread should be like the one in your vert.
http://geometroforum.com/single/?p=881109&t=4464045
geometromaniac
I havent taken the tank out yet from the 92 convertible. I do have access to a 1998 Metro ready for the scrap yard due to rust in the front suspension mounts. I can have anything I want off it. I am taking the front and rear anti sway bars to put on the convertible. Its a shame the car still runs well but is real rusty on the underside.
