| Rebuilding/repairing turn signal switch???; Possible or not? | |
| Tweet Topic Started: May 16 2014, 10:42 AM (344 Views) | |
| cwatkin | May 16 2014, 10:42 AM Post #1 |
I luckily had a spare turn signal switch to test in the new 1992. This was definitely the culprit for the non-functional signals. I couldn't get them to work for either direction. One of the stalks was busted so I took both switches apart and did a swap. These things are pricey enough that it would be rebuilding the old one. Is this possible? Has anyone done it and what is the usual problem? I am guessing that the circuitry itself has failed. I removed the protective vinyl cover on the wire bundle and inspected the wiring and connectors. Nothing was wrong there. Conor |
| David95237 | May 16 2014, 11:30 AM Post #2 |
Did you tug pretty good on the wires coming out of the plug? The vinyl can hide the break. |
| cwatkin | May 16 2014, 11:43 AM Post #3 |
I completely REMOVED the vinyl by cutting it off so all the wires were visible. Conor |
| cwatkin | May 19 2014, 09:07 PM Post #4 |
I just wanted everyone to know that I dis-assembled and cleaned my wiper/headlight switches. I applied dielectric grease and re-assembled. The problems with the switches were no more. Again, this was quite simple like most other things on a Metro. Conor |
| cwatkin | May 19 2014, 09:08 PM Post #5 |
This is definitely worth trying before replacing the switch. I looked at the prices and they were pretty high. Conor |
7:30 PM Jul 10
