What body parts are compatible with a 91 Vert?; Need an idea of what is compatible with a 91 Convertible.
Topic Started: May 18 2014, 04:22 PM (505 Views)
emperorvoid
HOPEFULLY getting a replacement Geo for the one some asshole arsonist burned down in front of my work this last year. The one I might be getting has some front end damage on the right side. Vert parts aren't exactly easy to come by most of the time so I am wondering if there are other makes and years that are compatible. Looks like I will need a front right fender, bumper, headlight, and hood. Thanks for any help!
mlillie
Sounds like the one in the Seattle area for sale.
mlillie
Check your PM.
t3ragtop
the right front fender on a vert has a hole for the radio antenna that is special to the verts. the left front fender is the same as the other metro/swift variants from 89 thru 94.
the verts used special "sport" bumper covers front and rear. the foam cores are the same as the other cars. the verts used the composite "lsi" headlights. everything else on the nose of the car is cross compatible.
the doors are different, the windshield is different, the brakes are different, the wheels are 13". the parts that vary from the hatchback and that are specific to the vert are largely interior trim, top and trunk related.
werase643
and you CAN use a quarter panel from a HB on a VERT.
jonathan180iq
Not Really All That Smart
I did a how-to on a headlight and front bumper conversion on my 'vert a while back. All parts came from 89-94 coupes. And as T3 said, one of the front quarter panels is usable.
I cannot comment on the rear bumpers, but I would assume those are interchangeable as well.
