93hb wiper motor wiring harness; anybody have or ?
Topic Started: May 25 2014, 08:54 AM (262 Views)
ISA911t
I need the wiring harness from the steering wheel to the motor - mine fried
or
can anybody tell me on the connector to the wiper motor which each slot does ? The connector fried so the wires are not the same
I have the FSM diagram but I can not figure it out
I have the intermittent low hi system
driver top
driver bottom
passenger top
passenger bottom
Thanks
Robert
geopat
There should just be four blue wires in the conector. If you want to eliminate the connector you should just be able to just match up the wire colors. blue to blue. blue with white stripe to blue with white stripe and so on.
