| Evaporator solenoid? | |
| Tweet Topic Started: Jun 5 2014, 12:32 PM (810 Views) | |
| jazzmandolin | Jun 5 2014, 12:32 PM Post #1 |
Hope this is posted to the correct spot here? Anyway I have the infamous intermittent loud ticking coming from the solenoid. I have done the searching which is how I found that the tick is the solenoid and not a valve tick. Does anyone know it a new solenoid will still tick? Is the tick normal? If I could feel reasonably curtain that a new solenoid would not tick I would pop for the 89.00 one from Oreillys just to not have to listen to that darn tapping tick? DO NOT want to replace with new and still have the tickitytap. Any input greatly appreciated. |
| David95237 | Jun 5 2014, 12:37 PM Post #2 |
Mine ticks but I sure cant hear it over the motor. But I am half deaf. |
| jazzmandolin | Jun 5 2014, 12:44 PM Post #3 |
Mine is really quite loud! I can hear it come and go when sitting at a stop light. It bothers me sure or I would not be asking the question. I read several posts that pretty much said its normal and shows that its working properly. Read another and it said that the ticking means its cycling too often. Guess I am looking for someone who has replaced a ticking solenoid with new and if the ticking stopped or not? |
| Old Man | Jun 5 2014, 12:56 PM Post #4 |
The clicking noise may be normal and caused by a rubber isolator mount for the purge valve may be damaged or missing and the purge valve is just telegraphing the noise to whatever it is mounted on. Might want to check the mounting bracket |
| mwebb | Jun 7 2014, 10:46 PM Post #5 |
FOG
the purge valve is just a valve it may operate more often if flow is restricted or if the evap vent valve is clogged or if MR 02 sensor does not show a change when purge is active early systems were noisier than later systems because of mounting / damping issues as mentioned above do not replace the purge valve VW N80 valves (purge valves) have a small screen which cloggs as carbon from the canister migrates up the purge line i just remove the screen to resolve many evap flow issues others replace the N80 valve but it will clogg the screen again in 10k miles or less |
| jazzmandolin | Dec 16 2014, 08:11 AM Post #6 |
Finally got around to pulling a evap solenoid from the local pick and pull off a 180,000 97 1.0 and now I have NO TIC, TIC, TIC! Oh so nice to have the noise gone! Had it on for over a week now and no tic so great I like! I love the pick your own parts places! Got a blower motor and good resistor off the same car so now I have all fan speeds and no intermittent LOUD scream from the blower. Good, good! |
| jazzmandolin | Dec 27 2014, 12:26 PM Post #7 |
Well must say I am a little disappointed. Just did my fill up and miles calculations the same as I have over the last year and got 250 out of 6.5 gallon of gas. 38 mpg! Never drove over 60 mph the whole time and did the same work route I always do. Over many, many tanks and calculations over the last year I always got right around 44mpg and that was driving 70mph on hwy5 between Red bluff and Redding California once every fill up. OK I POSTED THIS UNDER THE WRONG TREAD I rewrite where it should be.
Edited by jazzmandolin, Dec 27 2014, 12:31 PM.
7:57 PM Jul 10
