The Red Baron; It's about to get nasty up in here.
Topic Started: Jun 5 2014, 11:26 PM (14,353 Views)
bkelly
Gear Head
This car is going to be insane... Keep up the nice work!
dueces
Lol thanks! It's taking some time, but it will get there. I will be extremely happy to see this thing run 11.0. Which I really don't think will be a problem with the hardware I have now, haha
I'm still shocked you even use the metro body at this point and not a tube frame with metro "skin" it would be real sick to have a tube frame car that looked mostly like any other run of the mill car but under its skin is a monster
dueces
That would have still taken a ton of time, and probably more money. There will need to be some sort of tubular front end reinforcements, But going full tubular frame seems a bit too much.
bkelly
Gear Head
dueces
Feb 18 2015, 01:12 AM
With that combo I would expect to see 11s easy.
I'm thinking more in the mid to high 10s as long as it sticks shouldn't be a problem.
Edited by bkelly, Feb 19 2015, 06:13 PM.
dueces
Well even in fwd n/a form I expect to see low 13's, so awd twincharged goodness should being some fun!
bkelly
Gear Head
Depending on what tracks you go to, you may want to budget for a roll cage soon and a fire suit... :thumb ^o) :thumb
On some tracks, you hit the 10's and they will require them.
dueces
Yup roll cage at 11.49. I plan to have one
bkelly
Gear Head
dueces
Feb 20 2015, 06:34 PM
:thumb
dueces
Slowly but surely, I drove her down the alley tonight!!! Brakes are spongy, downpipe is smoking, throttle body needs fixed, vtec needs implimented, but Damnit it drove down the alley!!!!!
pics or it didnt happen
dueces
Lol, it was loud, it's still trying to Rev at 3800 rpm. I need to fix the bypass in the throttle body. I'll get after it again sometime soon
dueces
Well I worked on the car some more last night. Got the car to idle better, turns out there was a massive leak through the IAC valve. Now I'm running into the issue of the thermostat not opening! Replaced it with a new one and still nothing. I try to bleed the air out but since it won't open it just boils the coolant that is in the engine. Frustrating
dueces
So I am not sure why the thermostat won't open, but I removed it completely and it stays steady at 190 with my fan on. This tells me a few things. Too small of a radiator, there is an issue thermostat related, and I probably need to use my fan as a puller and not a pusher.....
dueces
Ok, got some things accomplished today! It was a little cooler out today, and the car stayed in the 165-170° range while I took it out for a spin. Brakes feel extremely squishy, but they are manual brakes..... I'm starting auto tune, and it's doing ok so far, hopefully I can drive her around some more to get her dialed in real good.
Other than that, I need to get vtec hooked up using the nitrous in and out on the ms, then I can really blow these tires off!
