| Lights went out. This is why. Help? | |
| Tweet Topic Started: Jun 7 2014, 11:38 AM (611 Views) | |
| PsychedChicken | Jun 7 2014, 11:38 AM Post #1 |
So this happened![]() My lights started being finicky and only turning on sometimes. You could bump the wires under the dash to get them back on, but thats no longer working either. They just wont come on at all. How should I go about fixing this? |
| Coche Blanco | Jun 7 2014, 11:49 AM Post #2 |
Did this 2 years ago, still works. |
| Metromightymouse | Jun 7 2014, 11:56 AM Post #3 |
Or here is the thread in the "How To" section that will give you options and a full discussion of the issue. http://geometroforum.com/topic/2575236/9/#new Helps if I include the link...
Edited by Metromightymouse, Jun 7 2014, 12:03 PM.
| David95237 | Jun 7 2014, 11:59 AM Post #4 |
Need to know what year your car is , the fix is different for newer models. |
| ptcapboy | Jun 7 2014, 02:55 PM Post #5 |
read the post about headlight switch disassembly by dopeoperator-rocco709 may have the solution to your problem- |
| JimmyStewart | Jun 11 2014, 10:41 PM Post #6 |
I had this problem; except my headlights had been replaced by the previous owner with aftermarket HID lights. Apparently he had decided to cut the plugs that were for the original headlights. Then the HID lights had been hooked directly up to the battery with a relay. The relay was hooked up to the front auxiliary light for the switch. It took me awhile to figure all of this out because of the jumbled up mess of wires that accompanied this experiment. I went to a salvage yard and bought some stock headlights with the plugs. Then I spliced the plugs into the old wiring for the original headlights. Next, I had to fix the plug inside the car because it had been clipped. Yeah.... Real pain |
7:28 PM Jul 10
