'96 Metro UltraGauge stays on
Topic Started: Jun 9 2014, 04:59 AM (445 Views)
Tim Keith
The UltraGauge connected to the OBD2 port stays on when the ignition is off. The battery was getting discharged. Is there a problem with the ignition switch ? I didn't notice this until I went out to the Metro to get something at night and noticed that the UltraGauge was still lit.
flea
It is drawing power. I bought something like that that I used with the Torque App in my 98 and I left it in for a few days then one night I noticed a small red light on under the dash. Sure enough it was on and drawing from the battery. So, unless you have a very good battery, or drive your car every day, I would suggest that you disconnect it when you park your car.
Tim Keith
I think it needs an alternator. The battery tested okay, the alternator is not outputting enough. A couple weeks ago the belt stopped squealing, the alternator probably isn't drawing a load.
freegeo
I have a 96 and when the key is turned off the power to the OBDii connection under the dash should shut off. You have a wiring issue or someone has ran battery voltage to it. Back track your wiring. Pull the fuse for that circuit and see if it stays on.
Tim Keith
For now I'll install a kill switch
