Weird Wiring; Weird Stuff
Topic Started: Jun 13 2014, 06:17 PM (532 Views)
Nestol
Hello, I need help so I got my 97 Geo Metro 4 cylinder lsi :news first whats wrong not sure if normal but I have to turn on my lights for my stereo to turn on second when I use my E break my head lights turn off weird wiring or normal I don't know I'm a newbie to all this I live under a rock. If you need more info just ask I need the help I love my metro and want to fix it up. :drivin
David95237
Do your high beams work?
Nestol
They do
fireflyin
headlight problem is right from factory e brake is to cancel Day time running lights if u have lights on and u hit e brake they should stay on and for your stereo you have immunization wire as acc instead of white with black i would trace wires from back of deck n see if they tied red with orange i believe with the red off your deck u can find wire diagram at this links
http://geometroforum.com/topic/4021533/ by Jittney
http://geometroforum.com/topic/5078021/ by Jittney
http://geometroforum.com/topic/2575420/ by Johnny Mullet
faygoninja
i'm guessing you have an aftermarket radio. i put mine in with a pig tail harness and i dont have the same problem as you per se' but my parking lights come on with the car now and if i turn on my lights, the radio comes on. i havnt gotten around to checking it yet but i would check the radio wiring. the headlights are supposed to go out when you engage the ebrake.
Your headlights aren't working, probably because of a burned connector where the wiring harness from the switch plugs into the fusebox. You're driving around on the DRL's and they're supposed to go off when you pull the E-brake on.
Your stereo is wired up incorrectly. The lighting is a switched 12V tied to the dash lights, someone has used that wire for either stereo power or stereo memory.
