| 1990 Geo Metro Automatic; No power to coil (sometimes) | |
| Tweet Topic Started: Jul 8 2014, 11:52 AM (301 Views) | |
| BillMan | Jul 8 2014, 11:52 AM Post #1 |
I have a 1990 geo Metro Automatic California Regulation 4 door car. My car has spark, or no spark... When no spark, I'm guessing I have no power going to the coil. I tested for spark and had none (when car chooses to not start) I took off the positive and negative cables to the coil. Touched them together and held them together while someone else was trying to turn over the car. I got no spark, and no fuses blown. A few days later, the car started up again. After driving a while, it will choose to not start for a few days. I replaced the coil with a more expensive coil from part store, I now have code 41 flashing. Any ideas for a fix? can I just run positive and negative wire from the battery to the coil? or not a good idea? I don't know what the fix is or the problem is? |
| GeoStalker | Jul 8 2014, 12:25 PM Post #2 |
My daughter's 93 automatic was doing the same thing. It would start....it wouldn't start. Turned out to be the starter. |
| Old Man | Jul 8 2014, 01:35 PM Post #3 |
I would have thought the same except in his other thread on this same subject he indicated that he was losing spark also. I will stick to what I said on that thread: http://geometroforum.com/topic/5536487/1/#new if I was you I would check the interlocks that require you to be in park, or neutral with your brake on before the starter will engage. I am not sure what all is involved with the Geo Automatics, but I would check the interlocks. I am wondering if they are (almost) out of adjustment and work correctly sometimes but sometimes cut off your ignition wiring .......... |
7:28 PM Jul 10
