where is alternator? new battery dying; replacing alternator
Topic Started: Jul 11 2014, 08:11 PM (970 Views)
dukester
Stupid me--bought nw battery because I had to charge every few days--why o why didn't I simply put a meter on the battery to see how many volts were passing? Now after buying a new battery--day 3 and new battery needs a charge just like old battery-sooooo where is the alternator on this 2000 Suzuki Swift ( same animal as Geo Metro 4 cylinder stick.
If you look in the left side of the engine bay near the engine oil dipstick you should see it, it's toward the back behind the water pump, pretty hard to miss (even though its pretty well snug in the 1.3L)
Hotrodray1
Over Educated parts guy
Passenger side back at fire wall. Low on engine. Look at the water pump belt at the rear most pulley that is your alternator.
truckjohn
Just a question....
Any noisy squealing coming from under the hood?
don_dowdy
The next question is, how to get it out? Getting the bolts out isn't that bad, but getting the alternator itself to come out from under the intake is not a lot of fun. It might be slightly easier on a 5-speed, but I don't think so. Usually on the 4-cylinders, you move the alternator in different directions for about 10 minutes trying to find a big enough space to get it out, then it slips out of your hand and lands on your head.
nickb803
NickB803
Remove the black plastic air intake tube. Remove oil dip stick. Then you can remove and install.just turn slight sideways and it will pull right out
don_dowdy
Jul 12 2014, 12:21 AM
10 minutes? You must be a genius, or one of those guys who does the Rubik's cube in 90 seconds.
I F-ed around with mine for two hours, was toying with the idea of removing the steering rack. Finally I decided to just bend the A/C lines and pull it out the top.
