| No Dash Lights....; Wonder what I screwed up??? | |
| Tweet Topic Started: Jul 14 2014, 12:05 AM (1,075 Views) | |
| Rondawg | Jul 14 2014, 12:05 AM Post #1 |
A few months ago I removed the entire dash. I finally got it back together, the motor and tranny swap is complete and it runs good. All the gauges work, but no darn dash lites! The light for the Heat-A/C works and operates properly with the dimmer. I dont know if they worked prior to the dash removal and re-install. Did I miss a ground somewhere? Is there a seperate fuse??
| JimmyStewart | Jul 15 2014, 12:04 AM Post #2 |
If they were working prior to your dash removal, it might just be a loose wire somewhere. That's where I would start. |
| Bad Bent | Jul 15 2014, 12:50 AM Post #3 |
Check out Jittney's post on fuse boxes: http://geometroforum.com/single/?p=256778&t=2559772![]() 1 - Left Headlight: High Beam Indicator (10 Amp) 2 - Right Headlight (10 Amp) 3 - Parking Lights; Side Marker Light; License Plate Lights; Instrument Panel Lights (15 Amp) 4 - Fog Lights (15 Amp) 5 - Hazard Lights; Horn (15 Amp) 6 - Ignition System; Gauges; Warning and Indicator Lights; Radiator Fan Motor; Automatic Transaxle Speed Sensor (20 Amp) 7 - Heater; Air Conditioning (20 Amp) 8 - Stop Lights (15 Amp) 9 - Lighter; Radio (15 Amp) 10 - Backup Lights; Turn Signal Lights (10 Amp) 11 - Rear Defogger (20 Amp) 12 - Front and Rear Wiper/Washer (15 Amp) 13 - Not Used (20 Amp) 14 - Not Used (15 Amp) 15 - Not Used (10 Amp) Hope that helps. |
| Stiffchezze | Jul 15 2014, 08:39 AM Post #4 |
Sir Metrologist
Good news! The fact that the A/C/Heat light is working means that your fuse is OK. There is only one for dash lights. IIRC The only dash light we have are the a/c/Heat controls, defrost switch, rear wiper switch, (not in your case ) the radio and the speedo cluster.So from the sound of it, in your situation, it's just the cluster that's not working. I would start by unplugging the speedo cluster and then plugging it back in. Maybe one of the wires is not making a good connection. Other than that, it's time to breakout the FSM and start chasing wires. |
| Rondawg | Jul 15 2014, 12:22 PM Post #5 |
Thanks for the tips, will reply when I figger it out. (prolly next weekend before I look at it)) |
7:27 PM Jul 10
